roller
bigdaddy08302
One more roller replacement question. I got a really good deal on a set of rollers but I have a concern. The new rollers are for a 7/8 shaft and my trailer's shaft though hard to measure is about 3/4. Is that too much play? Should I try to find some kind of spacer/bushing? I assume I want a bit of play for them to roll without binding. thanks in advance for any help.
Ted
bigdaddy08302
Re: roller
I was hoping to find some expert help...I searched and couldnt find info on this subject in any threads
JimS123
Re: roller
Yes you need bushings. Take your parts to a plumbing supply house and look at PVC pipe and/or copper tubing. Something will turn up with the right ID and OD, or maybe a combination of 2 parts.
If you can't find appropriate parts, buy rollers fitted to the trailer. Sometimes a good deal isnt always a good deal.
garzilla
Re: roller
Get bigger bolts??
Drill out the mounting tabs.
bigdaddy08302
Re: roller
Great idea with the plumbing parts. The rollers were 19 bucks each on sale for 3.99...couldnt pass it up...I knew thee had to be a way to make it work. Thanks again.
NYBo
Re: roller
3/4" copper pipe may do the trick.
