belairbrian
- Aug 21, 2009
- 360
So the boat I recently purchased has 3 rollers under the keel, two 6 foot bunks and a v pad above the bow hook.
Boat is a 15 foot grumman aluminum center console with a 48 Spl . Weights hull around 480 motor around 190.
My question is should the bunks carry the bulk of the weight and the rollers only a little?
Currently the middle roller is split and the keel is down in the split, the rear is not touching and the forward roller is resting against the keel?
I plan to pick up new rollers tomorrow. Since the roller brackets are adjustable, should I loosen the brackets and lower the rollers placing all the weight on the bunks, then replace the rollers and just bring them up into contact with the keel?
