Rotation
joshstan1978
I have a 4.3 Mercuiser with an Alpha one gen one out drive. I noticed while I was replacing some belts that the info plate says rotation LH. I looked at my prop and I am almost certain it is a right rotation. I have been using the boat about four years and not noticed anything other than at low speeds the bow walks back and forth. Does the LH stamp indicate the outdrive turns counter clock wise and I need a left rotation prop?? Any advice?
Engine serial # 0c665456
Drive #0c708653
Bt Doctur
all 4.3`s are left hand rotation when viewed from the flywheel. all merc drives have a right hand rotation OF THE PROP
