Rotor Distributor Cap 4.3L EFI 1998
juruca
After 22 years i want to install preventive a new distribution cap and rotor.
Problem: Can not remove the rotor!
Does somebody know if the original rotor is also glued ?
Thanks in advance!
Thanks in advance!
Ayuh,..... Welcome Aboard,..... Donno why they do it, but yes, it's glued on,....
Just bust it off with pliers,.....
'n nope, I don't glue the replacements,.... it has nowhere to go,.....
Scott06
I had to use a chisel to cut mine off
poconojoe
I used a dremel with a cutoff wheel. But I was EXTREMELY careful as not to cut into the distributor shaft.
I made some scores in the plastic and broke the rest off with pliers and screwdriver.
Lou C
I'd love to know whose brilliant idea that was lol.
juruca
Oke, is it worth all the effort to demollisch the rotor ?
What is the risk if i leave the old rotor on and only replace the distributor...
Scott06
Yes just replace it it’s not rocket science
poconojoe
If you are referring to gluing the rotor, I'd say some engineer went just a little overboard when it came to the marine-ness of the situation, if you get my drift. Wink wink!
