RetiredSoldier919
- Aug 1, 2012
- 24
My bargain($2500) 1986 190 Horizon has a rotted transom. However the outboard seems solidly mounted. I trimmed it all the way up and pulled up on the lower half. The transom doesn't flex at all. I tapped around the outside of the transom, where the OB is mounted, and it sounds solid. A nice sharp knock. I drilled some inspection holes in the transom from the inside. The bit went in without any resistance, some spots the bit came out wet. I can't figure out what is holding the outboard so firmly. I'm not likely to be replacing the transom because I don't have the time to do it and I just want to be boating in my spare time. So with that in mind I've just been treating it with Minwax consolidant and Elmers wood restorer. In the pic you can see the white stuff, that's the Elmers. What is left is real solid now, just not very much left. I hope to get maybe the rest of this season and next year out of it. I'll probably keep the Mercury 150HP OB and part out some of the better parts. Then buy a boat and add my OB.
