camera guy
- Jul 26, 2009
- 12
I'm NOT a boat restoration guy -- so I may use some incorrect language (like floor instead of hull), but here goes. My father purchased this boat new when we moved from the lake -- with a 70 Evinrude, it proved to be a great boat to bring to the lake with a few people where you could ski and not leave people on shore. When I inherited the boat, it was still in wonderful (like new) condition. We used it a couple of times a year. The 'deck' covering needed replacement and I did that a couple of years ago. About that time, I lifted the boat to connect to the vehicle and I could barely budge it -- I thought there must be water in it but no -- and then I heard sloshing. Checking around, for the first time I realized the 'floation compartment was NOT a sealed unit. Finding the plug, a great deal of water drained out. A year later, my newly covered deck was 'bouncy' -- yep, rotting deck!!
So, I have removed the decking and the flotation styrafoam. HERE is my plan and where I need help (ok to call me an idiot if this is NOT workable)! I have cut the top (horizontal) fiberglass of the "supports - ribbing ??" exposing the rotting 1" wood. My plan is to keep the fiberglass intact and remove the boards and replace them and re-fiberglass the top.
Then I can't decide whether to use the cans of foam or cut pieces of Styrofoam for flotation.
And then how do I make sure water (that I find can come in around the storage area under the front seats) can make it's way to a 'new drain' that I'll have to make?
Finally, when I cut out the deck, I left about 2" of fiberglass around the sides so I can use that to fasten the decking and hopefully stabilize the boat.
OK -- now is any of that workable or will I just have a nice looking craft that will pull apart, leak, and sink???
THANKS -- the rookie (Camera guy)
