I decided to post this info in case it might help someone else in my shoes... I couldnt find any info other than soldering or crimping on to the wire coming out of the stator... This is assuming you have some decent wire left. In my case I didn't have any wire left that was good. I figured there must be a way to get to the windings under the factory cover and fix this stator rather than replace. It worked... Here is some info on what you will encounter...
Here is what I started with...
