hawkins1017
- Jan 19, 2005
- 7
i purchased a 1985 procraft today and seen a soft spot when i looked to buy . when i got home i started to remove carpet and decking and found lots of rot and termites.i removed all the rotted wood i could get to and sprayed throughly with termite killer.i do have some concerns with the wood i cannot see under rear deck and front deck.my question is this is the wood a majior support for the boat or is it just support the deck. the fiberglass surrounding the wood is good. but i know there is more rot under the rear deck. transom and rear battrie and gastank seem to be ok .were do i get the foam from to replace old it was infested with termites to . i purchased some 1x6 runners to replace the joist and a 4x8 x1/2 treated marine plywood to replace deck. next thing is on my motor the fin on the bottom was broken today by the guy i bought it from and i was in a hurry to get to work and did not notice should i be concerned with this. thanks for any help. i have some pics of rot on computer if that would help.
