Hello all<br /><br />I've got a 1966 18' Cresliner Fiberglass boat with a 1966 80 HP Super Sea-Horse Johnson outboard motor on it.<br /><br />1. The plywood on the rear of the boat between the motor and the fiberglass is rotting, is this a problem, and if so what is the best or easiest way to replace? Will any plywood do? and does it need to be glued on or anything like that? and lastly should I re-use all the nuts, bolts, and screws?<br /><br />2. I've noticed a small perfectly round hole in my shaft about a quarter inch above, and three inches in front (by the rear of the boat) of the gear vent screw. This hole has had some sort of foammy oil coming out of it, that smelt live fuel. Shoud I be concerned or is this normal.<br /><br />Happy Easter.
