Re: Rough idle..after tune up kit installed?
i don't think he was kidding, you wouldn't believe what people forget to do. Are you sure the spark plug gaps are suppose to be .019? that seems awefully small<br /><br />Are the points opening correctly at the right time? I mean, there is a cam lobe in the distributor that the points rotate around on to open and close. Now, if the points are on the high point of the cam, they should be opened and gapped to the specified gap. <br /><br />Check that and see what you find, and make sure they are gapped CORRECTLY, same with your plugs.
