hello new to the site
my name is jon and i own a 1991 bass tracker with a 40hp johnson
it has always been hard to start, it will pop right off and run for a short time and die quickly many times i would have to take the cover off and give it more gas right as it starts till it warms up a bit- or as soon as it starts i must put it in gear and take off and all will be fine... i changed the choke seloniod and it didnt really help and i have cleaned the carbs my self fresh gas and cleaned the gas tank completly. im starting to lean towards that there is a leak some where on the fuel system? any other ideas what it can be
it will have a rough idle and after a while of idle it will die on its own (maybe 5 minutes or so)
then the last time i took it out i noticed the battery gauge was low while driving at 4200 rpm the gauge was reading @10 to 11 volts and i noticed that starter was slowing down a bit before heading back to the slip, after doing some fishing. i was wondering what is the odds that my battery is going south or is it the Stator?
can i connect a volt meter to it and check the output much like on a cars battery while checking the alternator?
if so what should it be running at?
and if it may be the Stator can you point me in the direction of which one i have/ need?
i saw that they sell a Stator for @$17 looks like a coil on a small lawn mower but sits under the flywheel
or is it the one that looks like a chargeing system off of a large lawn trackter rounded with several coils on it maybe 6 and that runs about 150 - 180 bucks???
thanks for any help
i would love to take it to a shop and have them look at it but i just dont have the cash to spare and i am very good with my hands and know my way around and engine but im rather new to outboards!
thanks for any help
