jedimaster
- Jun 8, 2006
- 336
3.0 mercruiser, 1988 140hp
The engine is running great while under throttle Getting 3600rpm at wot with a 19 pitch 3 blade alluminum and good power out of the hole.
But it idles really rough.
I have set the timing, has had a can of seafoam run through, rebuilt the carb(idled rough before as well), Replaced the plugs and wires.
What next? I have the RPM's at idle set at 800. If I raise it to 1,000 rpm idle it seems to idle fine? Is the idle mixture out maybe? or should I just turn up the idle rpm's?
It will eventually stall as it almost sounds like its running on 2 cylinders, its really rough.
