Re: rough running at low speeds
I had close to the same problem with my Chrysler 140. It turned out to be the diaphram in the fuel filter. If it gets a small pin hole in it, it will run rough at low RPMs and good at higher RPMs. Its just a piece of rubber and can easily be replaced.
