just purchased a lowrance x-88df new in the box. gonna install it on a 16' westcoaster. there is definately more cable than needed, being as it will be mounted no more than 40" from the stern. is it ok to just coil the cables and wire tie it ? i've seen mentioned that having the cables to close to one another may cause noise. is the power cable the only cable to worry about? thanks in advance.
