Re: RPM in rev. @ foreward
What JB said.<br />And Welcome to iboats.com
<br /><br />And to make sure the linkage is giving you WOT in forward, with the motor NOT running, push the binicle full-forward (WOT). Now, remove the cowl, and insure that the butterflies (the plates inside the carb), are opening fully, and not just partially. If they are opening fully, your linkage is fine. Note that under normal conditions, the original settings rarely change with timing adavance and associated linkage on these (and most) outboards. They are set-n-forget.<br />So i would forget them unless you know for sure that they have been futzed-around with.
