Re: rpm meter
This should help you get through it. It's in Adobe format. Basically, you hook up the gray wire under your dash, if there is one their, to SEND termimal on the Tach. There should be a purple wire that goes to the I terminal on the tach and of course, a ground wire is needed. If you want it backlit, just tag into one of the other gauges. Depending on the control you have, they make a harness that comes out of the control for all these wires. Look on you control for a 3 pin connector and this will simplifiy it.<br /><br />EDIT: Sorry, forgot link:<br /><br />
web page
