Beautiful day in the N.E..Took My 18ft wellcraft to the boat ramt to run it in water. I usually just use muffs at home. I read in a post to set the timing you need 5000rpms. Someone posted to back down a ramp put it in gear go to 5000 and set the timing. I put my 1988 150 blk max in gear and could only get to 2200rpm.{ I did not give it all cause I did not want the boat in the back of my pickup}.My question is what kind of rpms should i get on the motor when in gear 2/3 up?<br />Thanks, Dead Eye
