rpm variation in port engine
carver
my 5.7l mercruiser engine varies sometimes up to 300 rpm with no change in speed it does stay in long at one range. this does not happen all the time both engines and still have problem mechanic is miffed. coud it be a prop isssue ist is not cavitation
would appreciate some elp thanks
ScottRogers
Re: rpm variation in port engine
300 RPM is nothing to be concerned about, how is the tension on the throttle? Or more than likely your gauge is off just a bit
carver
thanks for your response. I can feel the engine rpm increase without any incresae in speed so I doubt it is the gage. Could it be something with the prop
