Rpm - wot
heyketz
Might be a dumb question but when talking RPMs and WOT does RPM refer to the engine RPMs or the prop RPMs.
90stingray
Re: Rpm - wot
To get prop rpm's you would have to multiply engine rpm by your drive ratio. But who the heck needs prop rpm's?:p Just fyi... incorrect prop or poorly running engine can contribute to low WOT. But usually prop pitch and WOT are directly related.
cr2k
Re: Rpm - wot
OK I'll answer your question. RPM refers to Engine RPMs, WOT means Wide Open Throttle.
EddiePetty
Re: Rpm - wot
........To get prop rpm's you would have to multiply engine rpm by your drive ratio.........
To be totaly correct:
To get prop rpm's you would have to DIVIDE engine rpm by your drive ratio.
1980Coronado
Re: Rpm - wot
You beat me to it......prop spins slower than engine, not faster.....he may have meant you multiply rpm X (1/x.xx) which works too. but I digress.
90stingray
Re: Rpm - wot
Didn't sound right, but i went with it... i knew someone would straighten me out.
HT32BSX115
Re: Rpm - wot
repeat after me........there are no dumb questions on iboats.......none !
ask with confidence bud.
welcome to iboats
Um....there's LOT's of DUMB questions on iboats!!!! (and even more misspelling, REALLY frustrating grammar, and incomprehensible sentences!!!)
But this one is not one of them!
