rpms 1997 200 efi
rmassie487vs
having apparently solved the mystery of the silenced beeper...now what is the recomended rpm range on the top-end for a 1997 mariner (magnum ?)efi 200hp
Skinsk
Re: rpms 1997 200 efi
If you look on the starboard center of the motor bracket, where the serial number is, you will probably find a it also tells you the RPM Range for that motor.
