Re: RPMS just not there
We need some more info from both of you. If all else is right, then probably yes the pitch is the problem.<br /><br />In the case of 16Pilot is the 21 inch prop new? As Don said, did this just happen? Or are there other things you changed prior to seeing this RPM? What was the RPM before?<br /><br />With Manipulator, I beleive the wide open throttle (WOT) range is 4400 - 4800, but it may have been 4200 - 4600. Anyway, most tests I have seen show that a prop that runs closer to the bottom of that range at WOT will be a little faster than one that runs towards the top of that range (fuel economy is usually better too). However, hole shot will be best with the prop that runs the higher RPM. 1 inch of pitch change usually results in around a 200 RPM swing.<br /><br />Also, make sure that you rtachometer is set to run the correct number of cylinders. There is often a switch for 8, 6 or 4 cylinders. See the topic for WOT and Propeller selection in the Engine FAQ section of this board it will help with more detail.
