RTV Silicone or Gasket Sealing Compound
turco555
Why is it recommended to use a joint sealing compound (solvent based) and not rtv silicone in marine applications? I have been doing a lot of research and they inform me that rtv silicone is better when no gasoline is used. That's why I don't understand why the other is used.
OMC sterndrive electric shift upper and lower unit.
dingbat
Two very different materials for two very different applications....
PRODUCT DESCRIPTION Sealant is a dark reddish brown, viscous liquid with a characteristic alcoholic odor. It is a slow drying, liquid that changes to a pliable, tacky film through solvent evaporation. It seals close fitting parts,machined surfaces and threaded connections in industrial,aircraft, marine and automotive applications.
PRODUCT BENEFITSFor close tolerance flangesSlow dryingFlexible settingWithstands pressures to 5000 psi
TYPICAL APPLICATIONS
Solid gasket dressingClose fitting machined surfacesThreaded connectionsAviation enginesMarine engines
PRODUCT DESCRIPTION Clear Silicone Adhesive Sealant is a general purpose, single component, room temperature vulcanizing (RTV) compound, designed for the sealing of mechanical assemblies. Upon curing from the exposure to moisture in the air, this non-sagging paste forms a tough, flexible, waterproof seal of silicone rubber, which resists aging, weathering and thermal cycling without hardening, shrinking or cracking.
PRODUCT BENEFITSEasy applicationApplied to horizontal or vertical surfacesSuperior adhesion and flexibilityWaterproofsInsulatesUnaffected by vibrationNon-flammableNon-toxic
GA_Boater
It's been my experience that solvent based sealants work well and easily separate and clean during disassembly.
RTV work well if you never have to disassemble and are darned near permanent. If you do manage to separate the parts, RTV resists cleaning from surfaces.
IMHO
