Rub rail
ledzeppelin135
Hi,
I am wondering what options I have for various rub rails that would look good on my boat and cover up the hull/deck joint fully. I am not sure what this boat had originally, but I am looking for something that is made to go on this and cover up this joint. Please let me know what you think,
Thanks,
Chris
wlg
Re: Rub rail
I had an old fiberglass boat that had a rub rail channel that fit over that seam. It had a putty like material behind it and screws held the rail in place. The putty was probably used as a water tight seal for the seam.
I don't know how big or what type boat you have, but I would assume that as long as it's not home made you should be able to find rub rail channel for it.
Re: Rub rail
Ayuh,... I ain't seen 1 with a rib like that,....
Kinda odd....
oops!
Re: Rub rail
thats a flange joint.
very rare now-a-days.
check out iboats for the correct rub rail.....you may have to phone them.......they have fantastic service and will get you the information you need
Woodonglass
Re: Rub rail
Uh Ohh, I think I found it...
http://www.wefcorubber.com/
ledzeppelin135
Re: Rub rail
Thanks for your help, I appreciate it, do you know of any rails that cover the area directly above and below the joint a little as well?
64osby
Re: Rub rail
I salvaged this off a 70's Larson, it had a similar seam. If you weren't so far away......
wlg
Re: Rub rail
I have the rail and insert off a 72 Silverline. It is similar to what 64osby has. If you were in the area we would load it up.
I know none of this helps you, I just wanted to let you know that this was the type of rail I was refering to in my first reply.
64osby
Re: Rub rail
The flange on my boat is probably 3/4" wide, would that type of rail work?
The Larson trim in the first pic - the center portion is 1/2" wide and tapers to 3/8" and it is 1/2" in depth so if yours is 3/4 in either dimension it wouldn't fit.
What came off of it?
