rubber diaphragm in the fuel pump on a 1986 85hp forces outboard motor
justmop
where is the rubber diaphragm in the fuel pump on a 1986 85hp forces outboard motor.. i need to know i think mine is split because i am dumping alot of fuel out but dont know where its going i need to know asapo thanks
maverick974
Re: rubber diaphragm in the fuel pump on a 1986 85hp forces outboard motor
Oooooh! I know this. I had the same problem not long ago. The diaphram is located on the passenger side just below the coils. Look for the round fuel filter with the large silver screw. That fuel filter is actually bolted to the diaphram housing.
justmop
cool iam going to go look now i am dumping alot of fuel right now i think that might have a split in it
justmop
is it easy to change and where did u get the gasket from
maverick974
Any boat place will have those or can order them. They are cheap as well. A couple of years ago when it happened to me, my fuel pump diaphram cost me under 3 dollars.
If for some reason you can't find one, I'm sure they are available online as well.
justmop
so how easy is it to change it looks like to me its just 5 screws .. so with that being bad would that make the gas come out of the exhaust...
roscoe
Yes a bad diaphram will dump fuel.
The old ones rotted from the ethanol in our gas.
The new ones are ethanol resistant.
You can got aftermarket kits here on iboats, or get a factory kit from any Mercury dealer.
The factory kit usually comes with an instruction sheet. Or at least they used to.
maverick974
It is just 5 screws. Take 'em out, pull off the diaphram, put in the new one, install 5 screws, sit down with a cold one and congratulate yourself on a job well done.
justmop
so i guess the diaphram is a gasket to ....if it clears up today i am running down to the boat to change it ... so did u notice a difference in the motor after changing it
maverick974
Well, no, it's not really a gasket but it's installed like one. I had a pin hole in mine and it ran horribly. I took it to 3 different mechanics and they couldn't figure it out. Once I finally found what it was and what it did, I changed it and it made all the difference in the world. With a bad diaphram, it leaks fuel directly into the cylinders and no matter what you do, the engine will run extremely rich. So rich that it hardly runs at all. I changed the diaphram and it instantly ran perfectly.
foodfisher
You will probably have to reset your idle speed.
justmop
well i just changed it and ran it for a test run it seem to run alittle better but it seem like the motor ran the same ...the only way i guess i can figure it out to see if its dumping alot of fuel is to take it for a long run... whats the normal constumpion of fuel burn i have a 7 gallon tank do i need to get a bigger one .. i didnt think i would burn 7 gallons in 4 miles
foodfisher
If your running against a 30 mph current or better.
justmop
what do u mean 30 mph current
foodfisher
I mean, it takes more fuel to go 4 miles upstream (against the current) as it does to go 4 miles against no current. Even less going downstream. How long did it take to burn 7 gals. going 4 miles?
justmop
about 25 min
foodfisher
Figure one gal. per hour for every ten hp. @ wot as normal. An 85hp should burn 8-9 gals. per/hr. Your numbers put you in the 16 gal/hr range. You've got some issues to deal with. Start w/ the link and sync sticky.then get back with specific items. The diaphram can be torn on installation if a burr on a screw grabs it and twists it as you tighten.
