rubber drain tube
Hi, I have removed my lower unit to replace the impeller, question is, there is a rubber tube that goes to a drain in lower unit. The tube had been plugged and placed doubled over where the gear shift rod goes thru the upper housing. It looks like it may have at one time attached to the lower cowl as a drain of some type. I cannot find on any diagrams. Is it common for this tube to be plugged and not attached? This is on a 35 hp, 1989 Mercury ser # 0b394125.
Thanks Jim
carholme
Re: rubber drain tube
That s/n comes up as:
MERCURY - ( 35 H.P. (1989 ))
Serial No: 0B394125 Model No: 1035312GD
Parts list for model 1035312GD:
35 H.P. - Mercury, Mercruiser, Force, etc. Parts Lookup
If you look at item 2 under GEAR HOUSING (DRIVE SHAFT) 35 H.P., that is a speedometer tube which would be connected to another tube running forward to a speedometer gauge on the instrument panel.
Service Manual P/N: 90-42794--1
Mercury Outboard Service Shop Manual Model 35 40 Boat Repair 90 42794 1 690 | eBay
Gerry
Thanks Gerry, as far as I know it has never been hooked up. Appreciate your help. Having trouble getting old impeller off, not the rubber but the brass insert that has the woodruff key; it is being stubborn, guess Ill have to chishel or cut as I think if I heat it might melt the shaft seal.
Thanks again, Jim
Silvertip
Any buddies have a modeling hobby? If so they will likely have a Dremel tool and a cutoff disk that will make short work of the impeller hub.
