Rubber exhaust Pipe fire
Raider316
2000 Bayliner I/O 5.0 Mercruiser
Took boat out and ran it for an hour or so.
As I slowed down smoke was rolling from the engine compartment. Apparently the rubber exhaust pipe on the exit side of riser was burning up. i cut it open but never saw flames but used fire extinguisher anyway.
The riser on that side was definitely hotter than the other side.
Engine temp was fine at 175 degrees.
Once it got towed back in. I test started it and it started up fine.
No water in oil engine
That's when I noticed the missing plug on the top of the exhaust manifold.
Could that have been the problem all along? Water was definitely coming out of it.
I have uploaded both sides of engine for reference
Any suggestions/ help would be appreciated.
alldodge
Have you been having troubles, if so what kind?
Yes with the plug gone there would be exhaust getting hot, water in the bilge,
Bt Doctur
must have had a lot of bilge water. Doubtful it fell out and there is no reason to remove that plug in the first place
Raider316
Thanks for the response. No problems at all. It was running pretty good.
Never realized I had a problem til I came to a stop.
achris
More fish than mountain goat
Pretty likely the exhaust shutters are fried.
tpenfield
Oh boy, what a mess you made . . . :)
Looks like you should . . .
Replace the missing plug on the manifold
Replace the rubber boot on the elbow
Replace the exhaust 'flapper' inside the exhaust tube.
Don't do it again :D
Lou C
Mystery is WHO removed that plug, they usually don’t come out by themselves and that’s not a drain plug obviously!
tpenfield
No longer a mystery. But there is another mystery - How does water drain up hill? :confused:
Must be for boating in Australia . . . achris any word on that :noidea: I know the water in the toilet spins the opposite way in the southern hemisphere . . . :D
JASinIL2006
ʍou ʎq ʇᴉ oʇ pǝsn sᴉ sᴉɹɥƆ 'ɥɐN
:lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol:
Raider316
UPDATE
Had time today to look at boat.
-All the rubber exhaust tubes on that side of engine are toast
- The mystery of the plug is solved. It basically melted and was blown out.
- the exhaust flaps are missing.
My question is could the flaps be lodged further down exhaust tube and clogging up exhaust? Maybe cause of all the problems?
I stuck a hose down the exhaust pipe but water did not back up.
I intend to replace manifold, riser and of exhaust flaps.
Ultimately I am concerned about the missing flaps and where they are.
Bt Doctur
The mystery of the plug is solved. It basically melted and was blown out. Well ,if it got hot enough to melt cast iron you have bigger troubles
Raider316
Plug was plastic
Engine is running fine outside of the overheating riser
