Rubber Washer on Lower Shift Shaft
greekfreek
There is rubber washer, 12-77674, just above the oil seal for the lower shift shaft. How is that positioned on the shaft, do I push it against the seal or let it set half way on the shaft?? Alpha Gen 2 Thanks
Bt Doctur
Re: Rubber Washer on Lower Shift Shaft
it fits in the recess and then the SS washer goes on top.
greekfreek
There was no SS washer, and none showing on parts list
Don S
Just down against the seal on the GenII. All it does is keeps sea critters and crud out of the seal itself.
Bt Doctur
Missed the GEN II part.
greekfreek
No problem, thanks all again....
