TheCat1212
- Feb 28, 2013
- 26
Here is a good one fore you guys. (Oh, and I already know this is crazy)..... I have a '83 25hp merc. tiller & a 14' alluminum boat. I want to steer from closer to the bow. (Already installed a steering wheel ).
I removed the tiller, along with the 2' cables & wires. I mounted it up front where I will be sitting and cabled with spiral & SS cables back to the motor. The Tiller mechanism is intact. Still works perfectly. The cables are tight (not too tight) with no slack and pull/push at the motor end nice and easy and smooth. But when I connect to the motor, it all binds up. It will not move in either direction. I am 99% sure everything is connected correctly. I AM MISSING SOMETHING AND IT'S DRIVING ME NUTS.
The Shifter/Throttle linkage assembly works fine without the cables connected (shift forward, throttle / shift aft, throttle). Basically all I did was lengthen the cables. Is there anything at the motor that the tiller does that I may have missed? I even have the new cables mounted at the motor exactly where the old ones came off. (on that bracket just in front of the linkage). i thought i would send this now. when the sun comes up, i will try to get some pics... thanks
