Rude 15hp Bogs down
ready4itall
98 evinrude 15hp
Model #:E15rle9r
Serial #:R OB545223
Helping out a buddy diagnose and fix bogging problem on his outboard.
Pumps water perfectly, starts up in 2 pulls, idles well, shifts well, but when in forward and given gas it starts to bog and eventually dies.
I'm thinking clean carb, but maybe some here can pitch in solution.
Thanks!
Scoobdrifter
take the carb off and clean the jets or give it some seafoam to see if that helps but jets need to be cleaned
oldboat1
See if you can keep it running with the hand primer (test fuel pump). If rebuilding pump, get a parts blow up to see assembly (pretty sure you can find service info here: http://boatinfo.no/lib/evinrude/manuals/1992-2001johnsonevinrude.html#/254 ) Believe the kit for that pump is available, if a little pricey.
would check fuel pump before rebuilding carb (and would stay away from seafoam for a suspected carb issue, unless using it to soak parts.)
