Hi
I have a 57 rude bigtwin sn# 25029-11326 this engine sat under a house for 3o years, it was seized up when I got it, I sprayed penetrating oil in each cylinder and let it soak for 10 days, and put a big breaker bar on her and she now turns over, I did a compression test with the electric starter and here are the numbers top cylinder is 110 & bottom is 147, what would cause this kind of range difference? I was thinking it could be just a ring sticking in the top cylinder and maybe if I could get her to start they might even out a bit, But will this thing even run with that kind of range difference? are there other things that would cause this? To me the bottom cylinder at almost 150 seems almost to high, or could this be from the penetrating oil? Anyway I would appreciate any help / advise, opinions, I really want to save this thing it dripps with KOOOOOL, thanks i/a
