Run carb out of fuel too long / bad fuel valve?
vildric
Hi!
I tried my little mercury 3.5 (4 stroke) for the first time today.
The user manual say to close the fuel valve and wait for the engine to stall after use.
I closed the fuel valve and waited on neutral for like 1 minutes and the motor never stalled.
Do you think that there is a problem with the fuel valve, or I didnt waited enough to empty the carb?
In either way, since I dont plan to use the outboard before a month, should I leave it that way or I should run it dry?
Thanks!
Start it up and let it run till it stops.-----It takes quite a while for it to run out.
vildric
Ok thanks, I thought that it would stall in like 2-3 seconds, not 2-3 minutes, I was worry that it was a bad valve.
GA_Boater
It is sipping fuel when idling, vildric. It will take some time before stopping.
