Run fuel out or not
sandbass
Should you disconnect fuel line and run the fuel out of the carbs after use if your going to use it the very next weekend. etc.
rickdb1boat
Re: Run fuel out or not
Not nessesary for short term storage.....If you are unsure of when you will get back out, add some Stabil to the fuel...
DHPMARINE
Only if you want to have a white powdery build-up in your fuel passages.(you cannot actually run it totally out of fuel,Either)<br /><br />DHP
sandbass
Seems to me if you run the fuel out of the carb. the wetting and drying effect will cause more varnish buildup that just leaving the fuel in it?
waterinthefuel
We run the fuel out every time we use our boat. We've never had a carb get clogged. Don't bother if you are taking it out the next day, week or even month. Sometimes its 6 months between outings for some of our boats. Stabil works wonders, we are currently running a tank with 2 year old gas and it works great.<br /><br />Our mechanics always told us run the gas out. So we do.
