running an engine outside of the boat
blackhawkdown
Once I've got my engine rebuilt I'd like to test it and adjust it before I put it back in. I've seen lots of people on Youtube do it. They usually mount it to a pallet and then hook up a hose, a fuel line, and the battery, etc. I can't seem to find a video or step by step instructions on how to do this. Seems straight forward but just thought I'd ask if anyone can direct me to a site or video or something on how this is done. It's a 302 188hp so it's gonna need to be strapped down tight. Saw Frisco Jarretts do it on his rebuild but couldn't quite catch all the things he did.
achris
More fish than mountain goat
Re: running an engine outside of the boat
All I do is sit my engine on a trolley I built specially for it, connect fuel, a battery, a water hose (make sure I have the exhaust directed away from anything that I don't want to get wet). I also connect my laptop computer (I have an MPI engine) so I have a 'dashboard' to monitor vitals.. I connect a remote starter switch so I can crank the engine, and use a short length of wire which I stick in the right holes in the harness plug as the 'key'....
Turn the water on, hit the starter switch, and it runs.. :D :D
Chris.......
blackhawkdown
Thanks Chris. You mentioned the part I'm missing. Which wires go where in the harness plug?
Bt Doctur
save your self the trouble and just run a jumper from the + battery to the + side of the coil, remote starter button to the slave .
achris
If you run a cable from the battery+ to the coil+, you bypass the resistance wire and could burn the points, or overheat the ignition coil... (as a quick test to make sure it's going to fire, sure, but to run until it reaches operating temp, not really)
Just link pins 5 and 6 on the big plug....
Cheers....
attachment.php
bonzoscott
And if you don't know what the remote starter switch is, go to Napa and ask for it. Great little tool.
achris
Don't think I could live without mine.... ;) (that and a multimeter)
