98 mercruiser 7.4 mpi. bravo1 as stated in title out cruising around and engine died, no audible alarm went off, turned off and turned key back on with no alarm at all , it would normally give the all clear alarm at start up. tried to crank up anyway and all it did was crank, no start. waited 20 mins. turned key on and got normal all clear alarm cranked and started. ran at idle about 2-3 mins did it all over again. oil pressure @40 idle, temp. @ 170, idle @ 600 rpm, new water/fuel sep. foot oil level on full. engine oil level on full. it acted like there was no power, no fuel, no spark , no go go anywhere. cranked and started back at home for about 2-3 minutes and continued the same problem. my wife says she noticed the rpms bounced from 1500-2300 in the driveway after it was all said and done. thanks in advance for your knowledge and help. i have been lurking on here awhile and have used alot of your info. jeff
