Have a 16' cc flats boat, I'm doing a bottom up. I need help figuring out how to run the gas lines, install the fuel tank, and so on.
I have a brand new Mohler Marine 19 gallon plastic gas tank. I want to place it under the front casting deck. There is no existing place for a gas fill on the boat since it is a project boat and there are no old gas lines. Can you tell me what the three valves shown are and what I need to do? I also have a "gas tank vent" that I have no idea what I'm supposed to do with.
Also, should I install a gas fill on the casting deck, if so, where? and how do I run the line to do that or does it have to be directly above the tank where I assume you fill it....
Its going to a 50 hp mercury (don't know if that matters.)
Anything helps guys!
Thanks.
Thanks.
