running good!!
spanishmak
I understand that with the red lever facing back (away from the bow)in line with solenoid is auto position but my question is my motor starts and runs better (on muffs)with the red lever facing towards the bow!I started the motor and with it running(lever on solenoid facing bow)I took off one of the primer lines and it is squirting gas,this should be flooding my motor right?But it is running fine,can someone tell me how this can be?My motor is a johnson 200 hp 1979,and the primer lines do not go to the intake by the carbs they go to the back of the motor by the cylinders.If you need pics let me know I will post them.This really has me stumped!
Joe Reeves
Re: running good!!
The 1979 V6 model (and others) uses a electric choke setup. If your engine is indeed a 1979 V6 model, then someone has made a conversion to the fuel primer solenoid setup for some reason.
Actually your engine is NOT running fine. The carburetors are fouled and the needed fuel to the cylinders is being provided only by the primer solenoid which you have in the full manual on position. Remove, clean, and rebuild the carburetors, and put that RED lever back where it belongs. See the below explanation pertaining to the fuel primer solenoid.
(Fuel Primer Solenoid Function)
(J. Reeves)
The RED lever...... The normal operating/running position is to have that red lever positioned over top of the solenoid and aimed at the other end of the solenoid, gently turned to its stop. This is the normal/automatic mode position. Pushing the key in opens the valve within the solenoid allowing fuel to pass thru it in order to prime and start the engine. Looking upon this solenoid as a electric choke results in a better understanding of it.
Having that red lever turned in the opposite direction, facing away from the solenoid, allows fuel to flow thru it to the crankcase area. One would only turn the red lever to this position in a case where the battery might go dead and the engine had to be started via the rope pull method. Look upon putting the red lever in this position as moving a choke lever on a choke equipped engine to the full closed position. Either one would supply fuel to the crankcase/engine for starting purposes BUT if left in that position while running would flood the engine.
The later model primer solenoids are equipped with a schrader valve, used for attaching a pressurized can of fogging oil etc, available at your local dealership with complete instructions.
Pumping the fuel primer bulb up hard fills the carburetor float chambers of course, but that process also applies fuel pressure to the primer solenoid.
The two small hoses leading from the primer solenoid branch off via tees to each fuel manifold section that would feed fuel to the individual cylinders.
Pushing the key in activates the primer solenoid to allow fuel to flow thru it to the intake manifold passageways. Cranking the engine over causes the fuel pump to engage which in turn sends fuel pulses to the primer solenoid via the 3/8" fuel hose.
Some engines incorporates the "Fast Start" feature which automatically advances the spark electronically so no advance of the throttle is required for starting.
Engines that do not have the "Fast Start" feature will be required to have the throttle advanced slightly.
Starting procedure: pump fuel bulb up hard, crank engine and push the key in at the same time. When the engine fires/starts, release the key so that it falls back to the run position.
Bottom line..... Look upon the primer solenoid as an electric choke.
Think about it... If your engine had an electric choke instead of that fuel primer solenoid, you wouldn't think of running the engine with the choke engaged full on.
