Running great and then quit
cimy3
Here is the boat's information: 1984 OMC Stringer: 140HP, 3L, In-line 4.<br /><br />I was out on the water for about 1/2 hour and everything was normal, then the engine shut down. No hiccups, no sputtering...it just died.<br /><br />After making it back to the dock (45 minutes later), the boat started again...first try no problem.<br /><br />I am thinking electrical...coil or distributor. What do you think? Thanks for the help.
Bob_VT
Re: Running great and then quit
Distributor's usually fail when hot. Maybe you just have a short. Use the manual and research it.<br /><br />Bob
salty87
how old is all of the ignition stuff...points, coil, dist., etc?
ss9940
My experience (similar symptoms) on a Volvo 3.0: The boat ran great, everything was fine, but wouldn't restart when i shut it down. The problem? The wire that goes from the distributor to the coil has a resistor in it - the contacts went bad so there was no connection between the pickup coil and the ignition coil - no spark. I almost went nuts looking for that problem - never thought it could be a WIRE!!! :D
D
DJ
Guest
My vote goes to the coil. If you do not have a resistor wire, the coil overheats.
cimy3
Thanks for the feedback...I am going to replace the points, condenser and rotor along with the coil. Thanks again for your thoughts.
D
DJ
Guest
If you have 12 or more volts engine running) at the coil, you'll overheat a new one too.
