Last year I noticed the head gasket was possibly blown as I only had 60 lbs of compression. I have replaced the head gasket and the exhaust port gaskets since. I used a friends infra temp gauge as I was running the motor in the driveway with the muff on it and there were areas of 240 -245 degrees. It feels like it's running hotter than I can ever remember. I also ran it at a lake and there was a pinhole size water squirt out of the top bolt of which I have stopped but the point being it was getting water up on top. I hear there is a small plastic bypass spring thing that goes into the block ... would this cause the oeverheating or running hot ? What next ?
