BigNick617
- Apr 26, 2011
- 2
Okay here goes... I have an 89 four winns 4.3 cobra... dewinterized the boat dropped it in the water took off... noticed that when I came to an idle the boat would slowly creep up towards 230 degrees... plane out and it cooled right down... okay... took it home inspected the impeller and it was fine just replaced last fall... housing looked okay and so did the gasket... hooked up the muffs and started frunning the boat at idle... slowly started geting hot... removed hose that goes into the thermostat housing from lower unit and was geting no flow... took off hose and impeller housing and backflushed the system... could push water up to the block and could push water out of the lower unit... hooked everything back up and put the muffs back on started the boat and could not get it to run over 170... cool right? took it to the lake... dropped it in... and before I could get out of the cove it was pegged... no flow coming from the lower unit... I am at a complete loss... someone please help... my next step is to replace the impeller housing gasket, housing, impeller, and water pump... already replaced the thermostat i forgot to mention... once again any help would be greatly appreciated...
