Running Hydraulic Lines
Biggyniner
I just finished up replacing the hydraulic lines (for trim control on the stern drive) in my boat. what a PITA!!!! For future reference is there an easier way to do this? Ended up feeding them through the transom from the outside but still took me a lot longer that it probably should have...
Biggyniner
Well they were both pulled lol, so I guess I had it as easy as I was going to get...
Ayuh,..... Pullin' through a string as you pull the old ones out, helps alot,.....
alldodge
Only way it can be easier with motor and drive removed, is having the transom assembly on the work bench
Easy is not on speaking terms with Boat :rolleyes:
