Running motor on land
Status
Not open for further replies.
robtherep
Hello<br /><br />Is there another system for running water through the motor besides the clamp with the big suction cups? On my 1067 evinrude 33 h the intake holes don’t seem to work with this method.<br />If I put the lower unit in a barrel of water can I take the propeller off to run it.<br /><br />Thank you
WillyBWright
Re: Running motor on land
If you don't, you'll splash all the water out in a few seconds. :eek: <br /><br />There was a hose adapter that attached to the antiventilation plate and fed the intake in front of the exhaust snout, but they never did work worth a crap. The barrel method is fine. :)
Paul Moir
You can leave the engine in neutral instead of taking off the prop. ;)
Dhadley
A motor that old that still runs? Be real careful because that baby has to be worth a fortune!<br /><br />Sorry, couldnt resist.
Paul Moir
:D I missed that. The outboard that propelled the Normans to victory eh?
peterc38
I wrap a bungee cord around the muffs to get a better seal
Chris1956
Roboat, If that motor has a grating above the anti-ventilation plant (water intake during reverse operation) you can try a standard pair of muffs. First tape the normal water intake behind the prop to seal it. Next remove one of the rubber muffs, attach the hose to the other one an slip the muff ove the LU until it covers the reverse water intake. You may need to pad the muff frame a bit.<br /><br />It is a bit messy but it worked OK for me.
Bob_VT
you can do as i do i built a run tank and it has cover over it where motor sits in water and a ex. fan to pull fumes out and the way its built i can run motor wide open and not a drop of water loss and gas fumes to chock on in the shop not hard to build and not too much doe ray me to build
can send pic if someone want to build one for them self
Announcement: -------------DO NOT reply to old threads or hi-jack new or old threads. Your reply WILL be DELETED. The old threads are for your information only when doing a search, and should not be resurrected. Click on this Announcement for further details. SEE ABOVE
Don S (Moderator)
Status
