Re: Running on Muffs
Hey Airman, It looks like your right. When talking to the Odyssey dealer, he said that what I thought was just a black plastic nut cover, was actually a button to push in and the lever would then act as a throttle. The dealer also said that normally this feature is not used much with the Computer set up, controling the motor, a lot better than they used too. So I guess it is just proof that the motor has been running pretty good up till now.<br /><br />It could be the coil like someone else posted, I might try to change that tomorrow, just to make sure, if it does not work, hey I will have a spare to keep in a Ziplock bag in case! <br /><br />But I betting the dealer is right, with the RPM reading being so iratic between switching Props, that there is some kind of computer control setting that has been off all along, which has worsened, or caused something else to finally go K put! <br /><br />Thanks for making me question my dealer, and learning that I can rev my engine. I might even try it, if I ever get it started again
<br /><br />Also Airman, I have no problem removing my Prop, I have been changing the prop every other weekend, trying to find the right prop, so I know it has been well greased. I also plan to keep it greased, and pull it from time to time.<br /><br />So far as pulling it when running on Muffs, I will ask the diagnostic testers, which way they prefer, I just have to warn the wife not to let my lab out, when testing. She is one of those that likes to stick her nose all up in where I am working on something. She has to be close, like she is helping or something. Otherwise, she has a nice seperate fenced in area, I can put her in when we have family functions outdoors. <br /><br />CaptHooknfinger, I think I answered your other post. You may well be right, but I was unable to see anything else loose, and believe me, I was searching for all I could to find the Quick-Fix-Plug in. I wanted to get it running as much as the next guy. I also thought it could be bad gas. But I did drain the fuel filter, fill with fresh gas, turned it over quite a bit on the muffs, and it hit a time or two, but would NOT RUN! So, My Mechanic friend is up to his eyeballs in work, so, I guess it is a wait to the diagnostic check.<br /><br />Thanks again Guys,
