I've made a few other posts about this, but it seemed like a good time to start over. I have a 1993 OMC Cobra 5.0 EFI that is not reaching WOT RPM. It tops out at about 3800 with the trim all the way down. With trim adjustment I can get 3900 and 40mph on a GPS. The only other symptom is a minor surge at idle (approx 150 rpm)
Recently I removed flappers lodged in the exhaust which significantly improved acceleration but only helped WOT RPM a little (change from 3500-3800). I checked the timing, and reset it to 5 deg BTDC. The TPS and MAP sensor both check out OK, and the throttle cable is adjusted per the instructions in the manual, but it does to seem to be restricted in the last tiny bit of travel.
The fuel pressure was checked a long time ago, but it might be worth another look. I'm planning on cleaning the flame arrestor which does have some belt dust on it. I also found a vaccum clamp missing on the VST so I'll be replacing that. I'm not particularly optimistic on either of these fixing it, so what else should I try?
edit: I should add that it throws a code 13 on the KOER test with a scan tool. I'm going to reset the idle using the correct procedure, but I don't think this has anything to do with my WOT RPM issue.
