TillamookB2
- Aug 5, 2010
- 24
I fixed the sticky float in the top carb of my Merc 55A and it runs... But its rough. If I rapidly press the electric choke, it runs much more smoothly. Once I quit with the choke, the idle speed goes down and it eventually stops. Should I tamper with the fuel/air ratio? Is there a proper way to do so? I have done nothing at all with the bottom carb, aside from a quick go-over with carb cleaner.
Also, I found that it sounds absolutely fantastic with a bit of throttle while rapidly opening/closing the choke.
