Just getting the 90' doral ready, and an issue I seen earlier in the year still exists...when started and left idle, temperature rises to about 200 and will quickly backs off if I give it some throttle, sometimes backs off on its own without giving it throttle. My first thought was impeller not pumping enough volume, but I had a a broken impeller on my old OMC and it was able to keep cool on the garden hose due to the tap water pressure, but would overheat on the lake. I'm guessing overheating @ idle on the garden-hose might be something other than the impeller
First I'm going to borrow an IR temperature gun to rule out a faulty gauge.
Then thermos stat
Ive read about the spring+ball in the cooling lines causing some issues, what should I look for there?
Then thermos stat
