Re: runs but poor idle
If you cannot correct your problem by adjusting the low speed mixture control, then it's time to go after the carbs - sounds like there's something crudding up the low speed jets. Try to get the OEM (Bombardier) rebuild kit from a dealer. It comes with a new plastic float to replace the old style cork one. The cork ones have a habit of sinking in today's gasoline.<br />The low speed orifaces (where the block is likely to be) are behind the soft core plug on the top of the carb, about even with the throttle butterfly.<br /><br />Good luck!
