Bearmanpaul
- Jun 29, 2018
- 6
I have a '91 Force 50 that I've been playing with for a while- new head gasket (was busted), new water pump impeller. The thermostat has been removed by the previous owner, probably because he knew there was a cooling problem. On muffs, it runs cool and plenty of water is being pumped- it comes out the plug hole at the top of the head when I remove it, the idle relief ports, and down by the prop. Then when I put it in a bucket or on the lake, it overheats almost immediately. The head gets to 212F measured with infrared thermometer, indicating there is water in there that is boiling. This tells me that the water is getting to the head and there is something blocking it farther down. However on muffs with the thermostat out, it only gets to about 100F. The back pressure on the exhaust from being submerged is stopping water flow. Has anyone had this problem, and if so what is it?
