Aq125a. 270OD. Hi again, boat stays at proper temp as long as I stay under 2400rpms or so? It can run at this speed and never gets hot,go past said rpms and she starts to get hot. Bring here back down ,and she cools right down?
I have resealed everything in the raw water system.new impeller ,flushed everything real good. When in the water and in neutral . There is good water flow out the exhaust,which is warm. How can I tell if the engine water pump is working properly? I have no leak in the closed system as it never looses any fluid. But I can't tell if the pump is working properly. It has a new thermostat,so that should not be a problem?
This is an old boat.but I have her looking good and have fixed most of her problems. Just a few little bugs to work out.
Thanks once again for any help.( I seem to say this a lot )LOL
Eddie
Eddie
