Runs in driveway not in water?
stan1
I have a Johnson V-4 140, 1983 model. Just aquired boat and thought I had it running great. Will start up and run fine at home but as soon as I back it in the water and try to start it, it will not run. It tries to start and will for a second and than dies. The longer it is in the water, the worse the problem. I take it back home and hook up the hose and it cranks right up. I am stumped.
kenmyfam
Re: Runs in driveway not in water?
Compression and spark check. Let us all know the results. Check fuel pump as well. mine started and ran fine on the muffs last summer till I got it on the water and then died out because the fuel pump was failing. Pump bulb when in the water and see if it still runs for you.
kenmyfam
And once again I forgot, welcome to iboats
