runs strong in reverse,bogs down then dies in forword gear
johnnyo2
i have a 1989 force 85hp,used to run good then all of a sudden boggs down an stalls in forward gear.i just replaced the water impeller.fuel pump flows good,put new plugs in,new primer bulb,good spark,idles ok,throttle cam pick-up point matches,throttle valves in sync.all this dose't matter because run great in reverse! WHY IS THAT dosen't the timing stay the same no matter what gear selected? linkage seams fine both ways HELP ME!
roscoe
Re: runs strong in reverse,bogs down then dies in forword gear
I suspect dirty carbs.
Can you keep it running in gear if you use the choke?
JB
You are dropping at least one cylinder, JohnnyO. It will seem fine in Neutral and reverse on one cylinder.
Try spraying fuel mix (NOT starter fluid) into each carb at idle. If the idle picks up that carb is at fault.
Good luck, and welcome to iboats. :)
